[postgis-users] edits to postgis_restore.pl
strk at refractions.net
Thu Dec 16 01:06:43 PST 2004
On Wed, Dec 15, 2004 at 01:00:28PM -0800, James Marca wrote:
> At approximately Wed, Dec 15, 2004 at 10:37:04AM +0100, strk at refractions.net wrote:
> > The postgis_restore.pl 'strips' postgis objects out of a dump.
> in looking at the postgis_restore.pl included in the 0.9.1 release, I
> noticed a typo. Then I added use strict; etc. and got a little
> carried away.
> I was intending to make some changes to address the new database
> issue, as well as the database user question which isn't addressed
> (presumes -U postgres, no password, etc), but haven't gotten that far.
> please review/test the attached patchfile. I don't have nearly enough
> test cases. In fact, all I have left is 0.9.0 and 0.9.1 PostGIS dumps.
> James
Thank you James, I'll take a look at it.
--strk;
> --- postgis-0.9.1/utils/postgis_restore.pl.orig 2004-08-20 07:52:10.000000000 -0700
> +++ postgis-0.9.1/utils/postgis_restore.pl 2004-12-15 12:42:21.000000000 -0800
> @@ -37,20 +37,78 @@
> # pg_dump-800/pg800 => pg_restore-800/pg800
> -eval "exec perl $0 $@"
> +eval "exec perl -w $0 $@"
> if (0);
> +use strict;
> +use warnings;
> +use Carp;
> +sub strip_whitespace_and_public {
> + #print "ARG1: [$arg]\n";
> + my $arg = lc(shift);
> + foreach ($arg){
> + s/^\s+//;
> + s/\s+$//;
> + s/^public\.//;
> + s/^opaque$/internal/;
> + s/^int[48]?$/integer/;
> + s/^float4$/real/;
> + s/^float8$/double precision/;
> + s/^varchar$/character varying/
> + return $arg;
> +my %obsolete_funcnames = (
> + 'plpgsql_call_handler' => 1,
> + 'unite_finalfunc'=>1,
> + 'postgisgistcostestimate'=>1,
> + 'wkb_in'=>1,
> + 'wkb_out'=>1,
> + 'ggeometry_consistent'=>1,
> + 'ggeometry_compress'=>1,
> + 'ggeometry_picksplit'=>1,
> + 'gbox_picksplit'=>1,
> + 'ggeometry_union'=>1,
> + 'gbox_union'=>1,
> + 'ggeometry_same'=>1,
> + 'gbox_same'=>1,
> + 'rtree_decompress'=>1,
> + 'ggeometry_penalty'=>1,
> + 'gbox_penalty'=>1,
> + 'geometry_size'=>1,
> +my %obsolete_funcids = (
> + 'geometry_union(geometry, geometry)'=>1,
> + 'geometry_inter(geometry, geometry)'=>1,
> + 'create_histogram2d(box3d, integer)'=>1,
> + 'estimate_histogram2d(histogram2d, box)'=>1,
> +my %obsolete_aggregate_names = (
> + 'fastunion'=>1,
> + 'mem_collect'=>1,
> +my %obsolete_types = (
> + 'wkb'=>1,
> (@ARGV == 3) || die "Usage: postgis_restore.pl <postgis.sql> <db> <dump>\nRestore a custom dump (pg_dump -Fc) of a postgis enabled database.\n";
> -$DEBUG=1;
> +my $DEBUG=1;
> -my %aggs = {};
> +my %aggs = ();
> my %fncasts = ();
> my %casts = ();
> -my %funcs = {};
> -my %types = {};
> -my %opclass = {};
> -my %ops = {};
> +my %funcs = ();
> +my %types = ();
> +my %opclass = ();
> +my %ops = ();
> my $postgissql = $ARGV[0];
> my $dbname = $ARGV[1];
> @@ -58,7 +116,7 @@ my $dump = $ARGV[2];
> my $dumplist=$dump.".list";
> my $dumpascii=$dump.".ascii";
> -print "postgis.sql is $postgsisql\n";
> +print "postgis.sql is $postgissql\n";
> print "dbname is $dbname\n";
> print "dumpfile is $dump\n";
> @@ -67,77 +125,50 @@ print "dumpfile is $dump\n";
> print "Scanning $postgissql\n";
> open( INPUT, $postgissql ) || die "Couldn't open file: $postgissql\n";
> -while( my $line = <INPUT>)
> + POSTGISSQL:
> + while( my $line = <INPUT>)
> $line =~ s/[\r\n]//g;
> #print "LINE: $line\n";
> - next if $line =~ /^ *--/;
> + next POSTGISSQL if $line =~ /^\s*--/;
> if ($line =~ /^ *create (or replace)? function ([^ ]*) *\((.*)\)/i)
> my $name = lc($2);
> my @args = split(",", $3);
> my $geomfound = 0;
> - for (my $i=0; $i<@args; $i++)
> + foreach my $arg (@args)
> - $arg = lc($args[$i]);
> - #print "ARG1: [$arg]\n";
> - $arg =~ s/^ *//;
> - $arg =~ s/ *$//;
> - #print "ARG2: [$arg]\n";
> - if ( $arg =~ /^int[48]?$/ ) {
> - $args[$i] = 'integer';
> - next;
> - if ( $arg eq 'float4' ) {
> - $args[$i] = 'real';
> - next;
> - if ( $arg eq 'float8' ) {
> - $args[$i] = 'double precision';
> - next;
> - if ( $arg eq 'varchar' ) {
> - $args[$i] = 'character varying';
> - next;
> - if ( $arg eq 'opaque' ) {
> - $args[$i] = 'internal';
> - next;
> - $args[$i] = $arg;
> - $geomfound++ if ( $arg eq 'oldgeometry' );
> + $arg = strip_whitespace_and_public($arg);
> + $geomfound++ if ( $arg =~ /oldgeometry/ );
> my $id = $name."(".join(", ", @args).")";
> $funcs{$id} = 1;
> print "SQLFUNC: $id\n" if $DEBUG;
> if ( $geomfound )
> - $arg = $args[$i];
> - $arg = 'geometry' if ($arg eq 'oldgeometry');
> - $args[$i] = $arg;
> - my $id = $name."(".join(", ", @args).")";
> - $funcs{$id} = 1;
> - print "SQLFUNC: $id\n" if $DEBUG;
> + foreach (@args)
> + s/^oldgeometry$/geometry/ ;
> + my $id = $name."(".join(", ", @args).")";
> + $funcs{$id} = 1;
> + print "SQLFUNC: $id\n" if $DEBUG;
> - next;
> + next POSTGISSQL;
> if ($line =~ /^create type +([^ ]+)/i)
> my $type = $1;
> $types{$type} = 1;
> print "SQLTYPE $type\n" if $DEBUG;
> - if ( $type eq 'oldgeometry' )
> + if ( $type =~ s/^oldgeometry$/geometry/ )
> - $type = 'geometry';
> $types{$type} = 1;
> - next;
> + next POSTGISSQL;
> if ($line =~ /^create aggregate *([^ ]*) *\(/i)
> @@ -152,23 +183,22 @@ while( my $line = <INPUT>)
> last if $subline =~ /;[\t ]*$/;
> - if ( $type eq undef )
> + unless ( defined $type )
> - print "Could not find base type for aggregate $name\n";
> - print "($line)\n";
> - exit 1;
> + warn "Could not find base type for aggregate $name";
> + warn "($line)";
> + confess;
> my $id = $name.'('.$type.')';
> print "SQLAGG $id\n" if $DEBUG;
> $aggs{$id} = 1;
> $aggs{$id} = 1;
> - next;
> + next POSTGISSQL;
> # CAST
> @@ -190,20 +220,17 @@ while( my $line = <INPUT>)
> print "SQLFNCAST $id\n" if $DEBUG;
> - my $id = $from.','.$to;
> + $id = $from.','.$to;
> $casts{$id} = 1;
> print "SQLCAST $id\n" if $DEBUG;
> - if ( $from eq 'oldgeometry' || $to eq 'oldgeometry' )
> + if(map { s/^oldgeometry$/geometry/ } ($from,$to) )
> - $from = 'geometry' if $from eq 'geometry';
> - $to = 'geometry' if $to eq 'geometry';
> - $casts{$id} = 1;
> - print "SQLCAST $id\n" if $DEBUG;
> + my $id = $from.','.$to;
> + $casts{$id} = 1;
> + print "SQLCAST $id\n" if $DEBUG;
> - next;
> + next POSTGISSQL;
> # OPERATOR CLASS
> @@ -212,7 +239,7 @@ while( my $line = <INPUT>)
> my $id = lc($1);
> print "SQLOPCLASS $id\n" if $DEBUG;
> $opclass{$id} = 1;
> - next;
> + next POSTGISSQL;
> # OPERATOR
> @@ -233,199 +260,121 @@ while( my $line = <INPUT>)
> $rarg=lc($1);
> - my $id = $name.','.$larg.','.$rarg;
> + my $id = join (',',$name,$larg,$rarg);
> print "SQLOP $id\n" if $DEBUG;
> $ops{$id} = 1;
> - if ( $larg eq 'oldgeometry' || $rarg eq 'oldgeometry' )
> + if(map { s/^oldgeometry$/geometry/ } ($larg,$rarg) )
> - $larg = 'geometry' if $larg eq 'oldgeometry';
> - $rarg = 'geometry' if $rarg eq 'oldgeometry';
> - print "SQLOP $id\n" if $DEBUG;
> - $ops{$id} = 1;
> + # my $id = $name.','.$larg.','.$rarg;
> + print "SQLOP $id\n" if $DEBUG;
> + $ops{$id} = 1;
> - next;
> + next POSTGISSQL;
> close( INPUT );
> #exit;
> # Scan dump list
> print "Scanning $dump list\n";
> open( OUTPUT, ">$dumplist") || die "Can't write to ".$dump.".list\n";
> open( INPUT, "pg_restore -l $dump |") || die "Couldn't run pg_restore -l $dump\n";
> +DUMPLIST:
> while( my $line = <INPUT> )
> - next if $line =~ /^;/;
> + next DUMPLIST if $line =~ /^;/;
> + next DUMPLIST if $line =~ /^\s*--/;
> - if ($line =~ / FUNCTION *([^ ]*) *\(([^)]*)\)/)
> + if ($line =~ /FUNCTION\s*([^ ]*)\s*\(([^)]*)\)/)
> my $funcname = $1;
> + # shortcircuit $funcnames on the naughty list
> + if (defined $obsolete_funcnames{$funcname}){
> + print "SKIPPING FUNCTION: [$funcname($2)] --- name on the obsolete name list" if $DEBUG;
> + next DUMPLIST ;
> #print "FUNCNAME: [$funcname]\n";
> my @args = split(",", $2);
> #print "ARGS: [". at args."]\n";
> my $wkbinvolved = 0;
> - $arg =~ s/^ *//;
> - $arg =~ s/ *$//;
> - $arg =~ s/^public.//;
> - next;
> - $args[$i] = $arg;
> - $wkbinvolved++ if ( $arg eq 'wkb' );
> + $wkbinvolved++ if ( $arg =~ /wkb/ );
> - $args = join(', ', @args);
> + my $args = join(', ', @args);
> #print "ARGS SCALAR: [$args]\n";
> my $id = $funcname."(".$args.")";
> #print "ID: [$id]\n";
> # WKB type is obsoleted
> if ( $wkbinvolved )
> - print "SKIPPING FUNC $id\n" if $DEBUG;
> - next;
> - if ( $funcname eq 'plpgsql_call_handler' )
> - next;
> - # This is an old postgis function which might
> - # still be in a dump
> - if ( $funcname eq 'unite_finalfunc' )
> - next;
> - # This are old postgis functions which might
> - if ( $funcname eq 'postgisgistcostestimate' )
> - next;
> - if ( $funcname eq 'wkb_in' || $funcname eq 'wkb_out' )
> - next;
> + print "SKIPPING FUNCTION: [$id] --- wkb type is obsoleted\n" if $DEBUG;
> + next DUMPLIST;
> - if ( $funcname eq 'ggeometry_consistent' ||
> - $funcname eq 'ggeometry_compress' ||
> - $funcname eq 'ggeometry_picksplit' ||
> - $funcname eq 'gbox_picksplit' ||
> - $funcname eq 'ggeometry_union' ||
> - $funcname eq 'gbox_union' ||
> - $funcname eq 'ggeometry_same' ||
> - $funcname eq 'gbox_same' ||
> - $funcname eq 'rtree_decompress' ||
> - $funcname eq 'ggeometry_penalty' ||
> - $funcname eq 'gbox_penalty' ||
> - $id eq 'geometry_union(geometry, geometry)' ||
> - $id eq 'geometry_inter(geometry, geometry)' ||
> - $funcname eq 'geometry_size' )
> - next;
> - if ( $id eq 'create_histogram2d(box3d, integer)' ||
> - $id eq 'estimate_histogram2d(histogram2d, box)' )
> - next;
> - if ( $funcs{$id} )
> - print "SKIPPING PGIS FUNC $id\n" if $DEBUG;
> - next;
> + print "SKIPPING FUNCTION: [$id] --- id on the obsolete id list" if $DEBUG;
> + next DUMPLIST ;
> print "KEEPING FUNCTION: [$id]\n" if $DEBUG;
> - #next;
> elsif ($line =~ / AGGREGATE (.*)\((.*)\)/)
> my $name = $1;
> - $arg =~ s/^ *//;
> - $arg =~ s/ *$//;
> - next;
> - $args[$i] = $arg;
> my $id = $name."(".$args.")";
> if ( $aggs{$id} )
> - print "SKIPPING PGIS AGG $id\n" if $DEBUG;
> - next;
> - # This is an old postgis aggregate
> - if ( $name eq 'fastunion' )
> - print "SKIPPING old PGIS AGG $id\n" if $DEBUG;
> - next;
> + print "SKIPPING PGIS AGG $id --- already in\n" if $DEBUG;
> + next DUMPLIST;
> - if ( $name eq 'mem_collect' )
> + if ( defined $obsolete_aggregate_names{$name} )
> - next;
> + print "SKIPPING old PGIS AGG $id --- name is on obsolete aggregate list\n" if $DEBUG;
> + next DUMPLIST;
> print "KEEPING AGGREGATE [$id]\n" if $DEBUG;
> - #next;
> elsif ($line =~ / TYPE (.*) .*/)
> my $type = lc($1);
> - if ( $type eq 'wkb' )
> + if ( $types{$type} )
> - print "SKIPPING PGIS TYPE $type\n" if $DEBUG;
> - next;
> + print "SKIPPING PGIS TYPE $type --- already included \n" if $DEBUG;
> + next DUMPLIST;
> - if ( $types{$type} )
> + if ( defined $obsolete_types{$type} )
> - next;
> + print "SKIPPING PGIS TYPE $type --- type is obsolete \n" if $DEBUG;
> + next DUMPLIST;
> print "KEEPING TYPE [$type]\n" if $DEBUG;
> - #next;
> elsif ($line =~ / PROCEDURAL LANGUAGE plpgsql/)
> print "SKIPPING PROCLANG plpgsql\n" if $DEBUG;
> - next;
> + next DUMPLIST;
> # spatial_ref_sys and geometry_columns
> elsif ($line =~ / TABLE geometry_columns/)
> #print "SKIPPING geometry_columns schema\n" if $DEBUG;
> - #next;
> elsif ($line =~ / TABLE spatial_ref_sys/)
> #print "SKIPPING spatial_ref_sys schema\n" if $DEBUG;
> - #next;
> elsif ($line =~ / OPERATOR CLASS *([^ ]*)/)
> @@ -434,9 +383,10 @@ while( my $line = <INPUT> )
> if ( $opclass{$id} )
> - print "SKIPPING PGIS OPCLASS $id\n" if $DEBUG;
> - next;
> + print "SKIPPING PGIS OPCLASS $id --- already included \n" if $DEBUG;
> + next DUMPLIST;
> + # no obsoletes?
> print "KEEPING OPCLASS [$id]\n" if $DEBUG;
> @@ -450,18 +400,27 @@ while( my $line = <INPUT> )
> my $id = $arg1."(".$arg2.")";
> if ( $fncasts{$id} )
> - print "SKIPPING PGIS FNCAST $id\n" if $DEBUG;
> - next;
> + print "SKIPPING PGIS FNCAST $id --- already included\n" if $DEBUG;
> + next DUMPLIST;
> #if ($arg1 eq 'box3d' || $arg2 eq 'geometry')
> #print "SKIPPING PGIS FNCAST $id\n" if $DEBUG;
> - #next;
> + #next DUMPLIST;
> - if ($arg1 eq 'wkb' || $arg2 eq 'wkb')
> + if ( my @badtypes = grep {defined $obsolete_types{$_}} ($arg1,$arg2))
> - next;
> + if ($DEBUG){
> + print "SKIPPING PGIS FNCAST $id --- type ";
> + print join ("and type ", @badtypes);
> + if(@badtypes>1){
> + print " are ";
> + } else {
> + print " is ";
> + print "obsoleted \n";
> + next DUMPLIST;
> print "KEEPING FNCAST $id (see CAST)\n" if $DEBUG;
> @@ -476,19 +435,33 @@ while( my $line = <INPUT> )
> my $id = $arg1.",".$arg2;
> if ( $casts{$id} )
> - print "SKIPPING PGIS CAST $id\n" if $DEBUG;
> - next;
> + print "SKIPPING PGIS CAST $id --- already included\n" if $DEBUG;
> + next DUMPLIST;
> #print "SKIPPING PGIS CAST $id\n" if $DEBUG;
> - #next;
> + #next DUMPLIST;
> - next;
> + if ($DEBUG){
> + print "SKIPPING PGIS CAST $id --- type ";
> + if(@badtypes>1){
> + print " are ";
> + } else {
> + print " is ";
> + next DUMPLIST;
> +# if ($arg1 eq 'wkb' || $arg2 eq 'wkb')
> +# print "SKIPPING PGIS CAST $id\n" if $DEBUG;
> +# next DUMPLIST;
> print "KEEPING CAST $id\n" if $DEBUG;
> print OUTPUT $line;
> @@ -500,9 +473,10 @@ close(OUTPUT);
> print "Producing ascii dump $dumpascii\n";
> open( INPUT, "pg_restore -L $dumplist $dump |") || die "Can't run pg_restore\n";
> open( OUTPUT, ">$dumpascii") || die "Can't write to $dumpascii\n";
> -while( my $line = <INPUT> )
> + ASCIIDUMP:
> + while( my $line = <INPUT> )
> + next ASCIIDUMP if $line =~ /^ *--/;
> if ( $line =~ /^SET search_path/ )
> @@ -539,11 +513,11 @@ while( my $line = <INPUT> )
> if ( $ops{$id} )
> print "SKIPPING PGIS OP $id\n" if $DEBUG;
> - next;
> + next ASCIIDUMP;
> print "KEEPING OP $id\n" if $DEBUG;
> print OUTPUT @sublines;
> - next;
> + next ASCIIDUMP;
> print OUTPUT $line;
> postgis-users mailing list
