[postgis-users] Intersects(geometry,geometry) fails
David Valentine
valentine at library.ucsb.edu
Tue Jan 13 07:31:02 PST 2004
logs that are not really useful.
Jan 13 06:54:44 apollo postgres[22673]: [ID 748848 local0.info] [8-1]
LOG: server process (PID 20490) was terminated by signal 11
Jan 13 06:54:44 apollo postgres[22673]: [ID 748848 local0.info] [9-1]
LOG: terminating any other active server processes
Jan 13 06:54:44 apollo postgres[20501]: [ID 748848 local0.notice] [8-1]
WARNING: terminating connection because of crash of another server
process
Jan 13 06:54:44 apollo postgres[20501]: [ID 748848 local0.notice] [8-2]
DETAIL: The postmaster has commanded this server process to roll back
the current transaction and exit, because another server
Jan 13 06:54:44 apollo postgres[20501]: [ID 748848 local0.notice] [8-3]
process exited abnormally and possibly corrupted shared memory.
Jan 13 06:54:44 apollo postgres[20501]: [ID 748848 local0.notice] [8-4]
HINT: In a moment you should be able to reconnect to the database and
repeat your command.
Jan 13 06:54:44 apollo postgres[22673]: [ID 748848 local0.info] [10-1]
LOG: all server processes terminated; reinitializing
Jan 13 06:54:44 apollo postgres[20502]: [ID 748848 local0.info] [11-1]
LOG: database system was interrupted at 2004-01-12 23:47:04 PST
Jan 13 06:54:44 apollo postgres[20502]: [ID 748848 local0.info] [12-1]
LOG: checkpoint record is at 5/ACC6B450
Jan 13 06:54:44 apollo postgres[20502]: [ID 748848 local0.info] [13-1]
LOG: redo record is at 5/ACC6B450; undo record is at 0/0; shutdown
FALSE
Jan 13 06:54:44 apollo postgres[20502]: [ID 748848 local0.info] [14-1]
LOG: next transaction ID: 7357507; next OID: 125349275
Jan 13 06:54:44 apollo postgres[20502]: [ID 748848 local0.info] [15-1]
LOG: database system was not properly shut down; automatic recovery in
progress
Jan 13 06:54:44 apollo postgres[20502]: [ID 748848 local0.info] [16-1]
LOG: record with zero length at 5/ACC6B490
Jan 13 06:54:44 apollo postgres[20502]: [ID 748848 local0.info] [17-1]
LOG: redo is not required
Jan 13 06:54:48 apollo postgres[20502]: [ID 748848 local0.info] [18-1]
LOG: database system is ready
Jan 13 06:56:18 apollo postgres[22673]: [ID 748848 local0.info] [11-1]
LOG: server process (PID 20754) was terminated by signal 11
Jan 13 06:56:18 apollo postgres[22673]: [ID 748848 local0.info] [12-1]
Jan 13 06:56:18 apollo postgres[20757]: [ID 748848 local0.notice]
[11-1] WARNING: terminating connection because of crash of another
server process
[11-2] DETAIL: The postmaster has commanded this server process to
roll back the current transaction and exit, because another server
[11-3] process exited abnormally and possibly corrupted shared memory.
[11-4] HINT: In a moment you should be able to reconnect to the
database and repeat your command.
Jan 13 06:56:18 apollo postgres[22673]: [ID 748848 local0.info] [13-1]
Jan 13 06:56:18 apollo postgres[20758]: [ID 748848 local0.info] [14-1]
LOG: database system was interrupted at 2004-01-13 06:54:48 PST
Jan 13 06:56:18 apollo postgres[20758]: [ID 748848 local0.info] [15-1]
LOG: checkpoint record is at 5/ACC6B490
Jan 13 06:56:18 apollo postgres[20758]: [ID 748848 local0.info] [16-1]
LOG: redo record is at 5/ACC6B490; undo record is at 0/0; shutdown
TRUE
Jan 13 06:56:18 apollo postgres[20758]: [ID 748848 local0.info] [17-1]
Jan 13 06:56:18 apollo postgres[20758]: [ID 748848 local0.info] [18-1]
progress
Jan 13 06:56:18 apollo postgres[20758]: [ID 748848 local0.info] [19-1]
LOG: record with zero length at 5/ACC6B4D0
Jan 13 06:56:18 apollo postgres[20758]: [ID 748848 local0.info] [20-1]
Jan 13 06:56:23 apollo postgres[20758]: [ID 748848 local0.info] [21-1]
On Jan 12, 2004, at 4:17 PM, Paul Ramsey wrote:
> Werks fer me.
> What GEOS version? Operating system, compiler?
> ogc=# select intersects(GeometryFromText('POLYGON((2 0,5 0,5 3,2 3,2
> 0))',54001),'SRID=54001;POLYGON((0 0,2 0,7 5,2 5,0 0))');
> intersects
> t
> (1 row)
> Greg Janée wrote:
>> Using Intersects(geometry,geometry) fails and furthermore causes the
>> database connection to get hosed:
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
> postgis-users mailing list
