[postgis-users] Win32 PostgreSQL 7.5/PostGIS snapshot update
Hisaji ONO
hi_ono2001 at ybb.ne.jp
Wed Jul 14 10:49:10 PDT 2004
Thank you very much for your quick response, Mark.
PATH correctly set, and execution initdb & pgstart
without problem.
I use env.bat for execution psql.
However I've got same errors.
psql:share\contrib\postgis.sql:38: ERROR: could not
access file
"$libdir/libpostgis.dll": No such file or directory
Environmental variable "libdir" seems to have no value.
How about this?
> It sounds as if the PATH environment variable is not
being set
> somewhere, so PostgreSQL cannot find libpostgis.dll.
> initdb.bat - to initdb the database cluster
> pgstart.bat - to run the database (leave this one
> running)
> env.bat - sets up cmd.exe with the correct PATH to run
> psql
> Please let me
> know if this doesn't solve the problem for you.
