[postgis-users] RE: install issues
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Wed Jun 16 21:58:05 PDT 2004
I think I figured this out:
- the psql command to run postgis.sql was choking on not being able to
find the geos libs.
Reading over the GEOS INSTALL again, I neglected to:
"Linux: Make sure that /usr/local/lib is added to /etc/ld.so.conf
       Make sure that you run /sbin/ldconfig afterwards"
...so I did this, and this seemed to work.
Thanks for the pointers.
..Tom
