[postgis-users] How to import e00 files?
Tue May 4 17:09:11 PDT 2004
Wood Brent wrote:
> I haven't tried Franks maptools suggestions yet.
> While the e00pg worked fine to get the line segments into PostGIS, & they
> display fine with JUMP, the e00 file (I think) contained topology info
> describing how to make polygons from the line segments. Each polygon is built
> up from a 1 OR MORE line segments.
> Will the maptools approach support the building of the polygons?
Brent,
Yes, ogr2ogr will see a PAL layer which is the formed polygons, with
any attributes on the original polygons.
Best regards,
