[postgis-users] Which SRID to choose?
Markus Spring
m.spring at gmx.de
Tue May 4 23:01:00 PDT 2004
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi list,
Markus Schaber wrote:
| There seems to be some difference between the EPSG codes in PostGIS and
| the actual EPSG data - when I look for the "Deutsches
| Einheitsdreiecksnetz" in Postgis, I get the SRIDs/EPSG-IDs 31491 to
| 31495, while the current EPSG database defines 31461 to 31469. Most of
| the other reference systems seem to match.
and it seems that I've stumbled across a similar problem.
Munich's Gauss-Krueger koordinates are told to be in EPSG:31468.
I can find this code in proj-4.4.7's /usr/share/proj/epsg file, but not
in the spatial_ref_sys table of postgis-0.8.1.
If the latter is deduced from the first, might it be possible to include
the conversion file additionally to or instead of
spatial_ref_sys.sql?
Please, could one of the developers shed light on this issue?
Kind regards
Markus Spring
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFAmIMcxxUzQSse11ARAjThAJ4pf5iT9olma0xUoM3f6471vXhr/wCfVgB+
ICJPHD3oZnSQAlFOQjkpUTY=
=VDKy
-----END PGP SIGNATURE-----
