[postgis-users] install problem
Camille Provost
cprovost at cetir.net
Wed May 5 01:13:12 PDT 2004
Hello
I'm trying to install postgis with postgresql on my Server running on Linux Suse 7.2.
I made the postgresql install successfully, but I've the following problem during the "make" of postgis (in the folder contrib of postgresql).
gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes -Wmissing-declarations -g -fexceptions -I. -DFRONTEND -DSYSCONFDIR='"/usr/local/pgsql/etc"' - DUSE_VERSION=74 -I/usr/local/include/geos -DUSE_GEOS -I/usr/local/include -DUSE_PROJ -DUSE_STATS -fpic -I../../src/include -D_GNU_SOURCE -c -o postgis_transform.o postgis_transform.c
postgis_transform.c:52: projects.h Aucun fichier ou repertoire de ce type
make: *** [postgis_transform.o] Error 1
I've the problem with 0.8.0 and 0.8.1 versions both.
I imagine that it comes from my configuration (Otherwise I won't have the problem with these two versions).
Thanks for your help
Cam
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040505/161885ee/attachment.html>
