[postgis-users] install problem
Benjamin Thelen
thelen at ccgis.de
Wed May 5 03:16:08 PDT 2004
Just a guess, but I you've requested proj (that's the default setting,
check postgis Makefile USE_PROJ=1) and don't have proj installed. Same
with geos! Either set USE_PROJ=0 or install proj/geos.
Regards,
Benjamin
CCGIS GbR - Bonn
http://www.ccgis.de
Siemensstraße 8
53121 Bonn
Germany
Tel: ++49 (0) 228 90826 15
Fax: ++49 (0) 228 90826 11
Camille Provost wrote:
> Hello
> I'm trying to install postgis with postgresql on my Server running on
> Linux Suse 7.2.
> I made the postgresql install successfully, but I've the following
> problem during the "make" of postgis (in the folder contrib of postgresql).
> gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes
> -Wmissing-declarations -g -fexceptions -I. -DFRONTEND
> -DSYSCONFDIR='"/usr/local/pgsql/etc"' - DUSE_VERSION=74
> -I/usr/local/include/geos -DUSE_GEOS -I/usr/local/include -DUSE_PROJ
> -DUSE_STATS -fpic -I../../src/include -D_GNU_SOURCE -c -o
> postgis_transform.o postgis_transform.c
> postgis_transform.c:52: projects.h Aucun fichier ou repertoire
> de ce type
> make: *** [postgis_transform.o] Error 1
> I've the problem with 0.8.0 and 0.8.1 versions both.
> I imagine that it comes from my configuration (Otherwise I won't have
> the problem with these two versions).
> Thanks for your help
> Cam
> postgis-users mailing list
