[postgis-users] install problem
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Wed May 5 03:07:21 PDT 2004
Hi Cam,
It looks as if the PROJ.4 library has not been installed correctly on
your server. Did you install the library from
http://www.remotesensing.org/proj/ using an RPM or a .tar.gz?
Cheers,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Camille Provost
Sent: 05 May 2004 09:13
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] install problem
Hello
I'm trying to install postgis with postgresql on my Server running on
Linux Suse 7.2.
I made the postgresql install successfully, but I've the following
problem during the "make" of postgis (in the folder contrib of
postgresql).
gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes
-Wmissing-declarations -g -fexceptions -I. -DFRONTEND
-DSYSCONFDIR='"/usr/local/pgsql/etc"' - DUSE_VERSION=74
-I/usr/local/include/geos -DUSE_GEOS -I/usr/local/include -DUSE_PROJ
-DUSE_STATS -fpic -I../../src/include -D_GNU_SOURCE -c -o
postgis_transform.o postgis_transform.c
postgis_transform.c:52: projects.h Aucun fichier ou repertoire
de ce type
make: *** [postgis_transform.o] Error 1
I've the problem with 0.8.0 and 0.8.1 versions both.
I imagine that it comes from my configuration (Otherwise I won't have
the problem with these two versions).
Thanks for your help
Cam
