[postgis-users] Startup problems :(
TECHER Jean David
davidtecher at yahoo.fr
Wed May 5 09:15:03 PDT 2004
that's not an error just a notice, a warning
TECHER JEAN DAVID
- Responsable Informatique 01MAP -
e-mail:davidtecher at yahoo.fr
Tél: 06 85 37 36 75
Site PostGIS: http://techer.pascal.free.fr/postgis/index.htm
-----Message d'origine-----
De : postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]De la part de
Maurizio Napolitano
Envoyé : mercredi 5 mai 2004 18:12
À : PostGIS Users Discussion
Objet : [postgis-users] Startup problems :(
Hi all!
I try to install the version 0.8.1 of postgis on a new machine.
On the machine before was a postgres installation stand-alone.
I removed it, download the postgres 7.4 source code.
Download the postgis source code and uncompress on the relative
"contrib" dir.
Changed the "[postgres_source]/contrib/Makefile".
Compiled all ... but ...
if i want use the file "postgis.sql".
I edit the file postgis.sql and change the path "$libdir" with
the path where the library "libpostgis.so.0.8" is located
(in my case: /usr/lib/postgresql).
If i import the file with the syntax
psql -f /location/of/postgis.sql -d mydatabse
i obtain a lot of errors, the first is some like:
type "histogram2d" is not yet defined
Solutions?
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
