[postgis-users] Re: Buffering a multipolygon gives Empty Geometry.
Paul Ramsey pramsey at refractions.net
Fri May 14 12:26:53 PDT 2004
Could you post your killer polygons to geos-devel? Hopefully some will
be better with the new GEOS, and others will shake out bug cases we have
not fixed yet.
rm_postgis at cheapcomplexdevices.com wrote:
> Paul Ramsey <pramsey at refractions.net> wroe:
>>OK, here is the odd bit about your examples: they are both buffer(0)
>>cases.
> The buffer(0) example was the test-case that I could isolate
> in something small enough to post to the mailing list.  I can find
> where the "geomunion" crashes with positive polygons
>>What are you trying to accomplish with this?
> A generic user-defined interface using mapserver-CGI that lets the end
> user say "give me all events withing X miles of the Florida A&M campus".
> If the end user happens to say '0', it ran the same query as if he said
> 1 mile that looks something like:
>    geomunion(buffer(the_geom,X))
>>That said, they should still work, so perhaps our buffer(0) semantics in
>>GEOS far fubar.
> With various geometries I can have geomunion crash on positive-sized
> buffers too; but the first one I saw had a zero, so I was thinking
> the empty geometry collection might have caused the geomunion to crash.
>>I found that example 1 worked with a positive buffer, but with 0 my test
>>platform gave the same results as yours, an empty geometrycollection.
> I can post larger examples (a dozen large polygons) that crash the backend
> but haven't been on the mailinglist long enough to know the etiquite of
> posting large exmaples..  Perhaps I'll put together a SQL script and
> post a link to it on the internet that show the problem with non-zero
> buffer sizes if that would be of interest here.
>    Ron
> postgis-users mailing list
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
