[postgis-users] Cygwin PostGIS Installer Problem
Steffen Macke sdteffen at web.de
Sat May 15 02:53:45 PDT 2004
Hello All,
Marc-Andre Morin reported a problem with the Cygwin PostGIS
installer 0.8.0 and the latest Cygwin PostgreSQL version (7.4.1).
Currently, I don't have a Windows machine around to reproduce the
problem (or create an updated version of the installer).
If you are experiencing the problem, you should find similar lines like
psql:/usr/share/postgresql/contrib/postgis.sql:41: ERROR:  Load of file
/usr/lib /postgresql/postgis.dll failed: dlopen: Win32 error 127
in c:\cygwin\tmp\create_dcmms.log
As a workaround, you can try to use Cygwin PostgreSQL 7.4 with
the 0.8.0 Cygwin PostGIS installer (If you still have a copy around).
If you have encountered similar problems, please share them
with the mailing list.
Steffen
