[postgis-users] postgis and mapserver problem
Jan Hartmann
j.l.h.hartmann at uva.nl
Mon May 17 06:10:31 PDT 2004
Hi Jeremy,
This seems to be the eternal STATUS DEFAULT problem. STATUS ON means
that the calling URL has to indicate explicitly that the layer should be
displayed (http://...?map=...&layer=...). Only layers with STATUS
DEFAULT are always shown. It is confusing, and you are not the first one
to have run into this.
Jan
Jeremy Palmer wrote:
> Hi I’m trying to display Postgis data through Mapserver but all I get
> back is a blank image. I have got mapserver demo/samples working with
> shape files.
> The map file I’m using is:
> NAME TEST
> SIZE 400 300
> # lat long extents
> EXTENT 5 -48 24 -35
> UNITS METERS
> IMAGECOLOR 255 255 255
> IMAGETYPE PNG
> #NZGD2000 datum
> PROJECTION
> "init=esri:104108"
> END
> LAYER
> CONNECTIONTYPE postgis
> NAME "node"
> # Trusted connection to db ‘dblh’ on host ‘lh-deimos’
> CONNECTION "user=postgres dbname=dblh host=lh-deimos"
> # Select column shape from table node
> DATA "shape FROM node"
> STATUS ON
> TYPE POINT
> CLASS
> COLOR 0 0 0
> END
> END
> END # Map File
> The http request I’m using is:
> http://lh-deimos/cgi-bin/mapserv?map=/var/www/htdocs/map/test.map&mode=map
> <http://lh-deimos/cgi-bin/mapserv?map=/var/www/htdocs/map/test.map&mode=map>
> I’m using:
> Postgresql 7.42
> Postgis 0.81
> Geos 1.0
> Proj 4.47
> mapserver 4.02
> Thanks
> postgis-users mailing list
