[postgis-users] GeomUnion function
Paul Ramsey
pramsey at refractions.net
Tue May 18 07:39:38 PDT 2004
From CVS,
multi(geometry)
P.
On Tuesday, May 18, 2004, at 07:24 AM, Hubert Fröhlich wrote:
> Hi list,
> I am working with Postgis 0.8.1 and GEOS 1.0.0, PostgreSQL 7.4.1 .
> I want to use the GeomUnion(geometry1, geometry2) function.
> When I apply GeomUnion on two arbitrary MULTIpolygons, I receive
> MULTIPOLYGONS or POLYGONS, depending on the relationship between the
> two geometries.
> However, when I want to insert the result into a table, I have to
> decide upon using only one geometry type.
> If the result is a MULTIPOLYGON and I insert a to a table with
> MULTIPOLYGONS, everything is fine.
> If the result is a POLYGON and I insert a to a table with
> MULTIPOLYGONS,
> I get a constraint violation like
> ERROR: new row for relation "lkrx" violates check constraint "$2"
> What I need is a function converting Polygons into Multipolygons or a
> GeomUnion function forcing MULTI... results.
> How can I do that?
> Regards,
> Hubert
> Dr.-Ing. Hubert Fröhlich
> Bezirksfinanzdirektion München
> Alexandrastr. 3, D-80538 München, GERMANY
> Tel. :+49 (0)89 / 2190 - 2980
> Fax :+49 (0)89 / 2190 - 2997
> hubert dot froehlich at bvv dot bayern dot de
> postgis-users mailing list
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
