[postgis-users] Building with mingw32, configure for PostgreSQL
Tyler Mitchell
TMitchell at lignum.com
Thu May 20 16:34:30 PDT 2004
Guys, this is great stuff.
For the reference of others, you can download the binaries and install
instructions for postgresql from:
http://www.hagander.net/pgsql/win32snap/
Then grab the files outlined below:
postgis-users-bounces at postgis.refractions.net wrote on 05/18/2004 03:47:08
AM:
> Hi
> I sent a mail to Wang about the compiled version of postgis that I made
> Postgis was compiled with GEOS, PROJ . So if you want Craig you can
download
> it at
> http://techer.pascal.free.fr/postgis/download/psqlwinpostgisdll75.zip
> There are
> postgis.sql, libpostgis.dll, postgis.sql, shp2pgsql.exe, pgsql2shp.exe
> open postgis.sql and replace C:/MinGW/psqlwin/lib everywhere in this
file by
> the path of libpostgis.dll
> The only error I have it that 'create index ... on ... using
gist(the_geom
> gist_geometry_ops)'
> works only on small tables. For large tables, postgres.exe makes an
error
> and stoppped.
> TECHER JEAN DAVID
> - Responsable Informatique 01MAP -
> e-mail:davidtecher at yahoo.fr
> Tél: 06 85 37 36 75
> Site PostGIS: http://techer.pascal.free.fr/postgis/index.htm
> -----Message d'origine-----
> De : postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]De la part de
> Craig Miller
> Envoyé : lundi 17 mai 2004 23:22
> À : PostGIS Users Discussion
> Objet : RE: [postgis-users] Building with mingw32, configure for
> PostgreSQL
> I was able to get everything to compile except PostGIS with GEOS
support.
> PostGIS w/o GEOS support works, and the GEOS compile works good too. I
saw
> in your notes that you said you had to copy the GEOS header files to
> /include. This directory does not exist in a default msys installation.
> Did you add it?
> Thanks,
> --Craig
> -----Original Message-----
> From: David TECHER [mailto:davidtecher at yahoo.fr]
> Sent: Monday, May 17, 2004 5:36 AM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Building with mingw32, configure for
> PostgreSQL
> Hi Craig
> can you give me the file or the URL where you have
> seen this?
> Did you succeed in compiling?
> > I remember that you posted a message about having
> > trouble creating indexes
> > on large datasets with the mingw version of postgis
> > you compiled. I read a
> > note in the postgresql compile notes that said to be
> > sure to run postgres
> > from a normal DOS cmd prompt and not an rxvt shell
> > due to some sort of
> > memory limitation. Perhaps this is what is causing
> > the trouble with large
> > datasets?
> > --Craig
> > Sent: Thursday, May 13, 2004 8:30 AM
> > Subject: Re: [postgis-users] Building with mingw32,
> > configure for
> > PostgreSQL
> > Dear Romi
> > thanks thanks very much I succeed I succeed after
> > two
> > weeks of work
> > I'm happy...You know I'm happy :)
> > Yahoo! Mail : votre e-mail personnel et gratuit qui
> > vous suit partout !
> > Créez votre Yahoo! Mail sur
> > http://fr.benefits.yahoo.com/
> > Dialoguez en direct avec vos amis grâce à Yahoo!
> > Messenger !Téléchargez
> > Yahoo! Messenger sur http://fr.messenger.yahoo.com
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> Yahoo! Mail : votre e-mail personnel et gratuit qui vous suit partout !
> Créez votre Yahoo! Mail sur http://fr.benefits.yahoo.com/
> Dialoguez en direct avec vos amis grâce à Yahoo! Messenger !Téléchargez
