[postgis-users] psql crashes if bbox is too big
Gerry Creager N5JXS
gerry.creager at tamu.edu
Sun May 23 08:59:16 PDT 2004
I've often had more than 10 outstanding postgis requests up. What sort
of machine, memory, etc? Sounds like a resources issue. Have you run
'top' and seen what is going on?
gerry
Sunny Leung wrote:
> Follow up onto my problem.
> I notice each time a request to the WMS to the postgis datastore, a
> postgres process appear in the server ps list. Below is a capture from top:
> 2633 postgres 9 0 2100 2100 1700 S 0.0 0.2 0:00 postmaster
> 2635 postgres 9 0 2060 2060 1664 S 0.0 0.2 0:00 postmaster
> 2637 postgres 9 0 2092 2092 1668 S 0.0 0.2 0:00 postmaster
> 3842 postgres 9 0 5072 5072 3616 S 0.0 0.4 0:00 postmaster
> 3844 postgres 9 0 4852 4852 3596 S 0.0 0.4 0:00 postmaster
> 3846 postgres 9 0 5044 5044 3596 S 0.0 0.4 0:00 postmaster
> 3848 postgres 9 0 4852 4852 3596 S 0.0 0.4 0:00 postmaster
> 3852 postgres 9 0 5048 5048 3596 S 0.0 0.4 0:00 postmaster
> 3854 postgres 9 0 4856 4856 3596 S 0.0 0.4 0:00 postmaster
> 3856 postgres 9 0 5048 5048 3596 S 0.0 0.4 0:00 postmaster
> 3858 postgres 9 0 4856 4856 3596 S 0.0 0.4 0:00 postmaster
> 3863 postgres 9 0 5048 5048 3596 S 0.0 0.4 0:00 postmaster
> 3865 postgres 9 0 4860 4860 3600 S 0.0 0.4 0:00 postmaster
> 3867 postgres 9 0 5052 5052 3600 S 0.0 0.4 0:00 postmaster
> 3869 postgres 9 0 4860 4860 3600 S 0.0 0.4 0:00 postmaster
> 3871 postgres 9 0 5052 5052 3600 S 0.0 0.4 0:00 postmaster
> 3873 postgres 9 0 4860 4860 3600 S 0.0 0.4 0:00 postmaster
> 3876 postgres 9 0 5052 5052 3600 S 0.0 0.4 0:00 postmaster
> 3878 postgres 9 0 4860 4860 3600 S 0.0 0.4 0:00 postmaster
> 3880 postgres 9 0 5052 5052 3600 S 0.0 0.4 0:00 postmaster
> I suspect the postgres crashes because of the increase number of
> postgres processes created in the server. After about 10 request to the
> WMS, the postgres crashes.
> Is this a configuraiton problem, how can I solve it. Thank you very much.
> Best regards,
> Sunny Leung
> Sunny Leung wrote:
>> Dear all,
>> I have converted a couple of shapefiles to postgis. Currently, I am
>> using geoserver WMS to draw the map from the postgis datastore. I
>> observed, if my bbox is larger than the mapping data itself, the psql
>> server crashes.
>> I observed the following error messages:
>> "psql: could not send startup packet: Broken pipe"
>> In order to recover the problem, I have to restart the postgres server
>> but the problem reappear if I use a bbox larger than the map data itself.
>> Would someone give me some directions as to what causes this problem
>> and how this can be resolved. Thank you very much.
>> Best regards,
>> Sunny Leung
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
