[postgis-users] psql crashes if bbox is too big
Gerry Creager N5JXS gerry.creager at tamu.edu
Sun May 23 08:48:03 PDT 2004
First thought is that the postGIS instance might not have been started
with internet connectivity enabled.
gerry
Sunny Leung wrote:
> Dear all,
> I have converted a couple of shapefiles to postgis. Currently, I am
> using geoserver WMS to draw the map from the postgis datastore. I
> observed, if my bbox is larger than the mapping data itself, the psql
> server crashes.
> I observed the following error messages:
> "psql: could not send startup packet: Broken pipe"
> In order to recover the problem, I have to restart the postgres server
> but the problem reappear if I use a bbox larger than the map data itself.
> Would someone give me some directions as to what causes this problem and
> how this can be resolved. Thank you very much.
> Best regards,
> Sunny Leung
> postgis-users mailing list
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
