[postgis-users] Re: Win32 PostgreSQL 7.5/PostGIS snapshot
Emil Zegers
EZS at DeStraat.NL
Fri May 28 03:48:55 PDT 2004
Hello Mark,
Your Win32 PostgreSQL 7.5/PostGIS snapshot is working great!
This morning I downloaded and installed the newest version with GiST index patch.
Imported some shapefile data (point file with >88000 points) and made indexes on it.
I'm viewing the data through a MapServer client.
Performance is great and the database is stable too on my Windows 2000 system.
About the batch files running order: I run env.bat before initdb.bat otherwise the path is not correct.
Thanx for the 'Ctrl-C' tip to shutdown the server.
If I restart the system without shutting down I get a BSOD before rebooting.
Again, thanks for sharing this software.
Best regards,
Groeten,
Emil Zegers
De Straat Milieu-adviseurs
Divisie Informatisering
026 7513902
06 22965585
http://www.destraat.nl
______________________________________________________
This message has been checked for all known viruses
