[postgis-users] Re: Win32 PostgreSQL 7.5/PostGIS snapshot
    bartvde at xs4all.nl
    Fri May 28 07:13:23 PDT 2004
Hi Mark,
great. Finally I got PostGIS to work on Windows thanks to you.
What would be involved in changing the data directory to another drive (my
c: drive is not large enough for all the data I want to put into PostGIS)?
Do I only need to change the following line in initdb.bat:
initdb.exe -D c:\pgsql75win\data
or is there more effort involved?
Thanks in advance.
Best regards,
Bart
> Hello Mark,
> Your Win32 PostgreSQL 7.5/PostGIS snapshot is working great!
> This morning I downloaded and installed the newest version with GiST index
> patch.
> Imported some shapefile data (point file with >88000 points) and made
> indexes on it.
> I'm viewing the data through a MapServer client.
> Performance is great and the database is stable too on my Windows 2000
> system.
> About the batch files running order: I run env.bat before initdb.bat
> otherwise the path is not correct.
> Thanx for the 'Ctrl-C' tip to shutdown the server.
> If I restart the system without shutting down I get a BSOD before
> rebooting.
> Again, thanks for sharing this software.
> Best regards,
> Groeten,
> Emil Zegers
> De Straat Milieu-adviseurs
> Divisie Informatisering
> 026 7513902
> 06 22965585
> http://www.destraat.nl
> ______________________________________________________
>  This message has been checked for all known viruses
> postgis-users mailing list
