[postgis-users] Incorrect results from queries specifying an SRID
cp
cplists at yeroc.ca
Fri May 28 13:28:11 PDT 2004
Paul Ramsey wrote:
> cp wrote:
>> My expectation would be for postgis to automatically transform the
>> coordinates to match the SRID of the geometries stored in the table
>> (4267) or at least to give me an error.
> You should be getting an error, that is the only noticable bug. SRID
> mismatches are supposed to raise errors (to prevent precisely the
> problem you demonstrate going quietly unnoticed).
Ok. Any ideas why I'm not getting an error? Is there any diagnostic
information I can gather to track this down?
>> My workaround for now is to wrap my query with a transform myself
>> like so:
>> SELECT * FROM gis
>> WHERE geometry && transform(GeometryFromText('BOX3D(325356
>> 6341280,335614 6328019)'::box3d, 26712), 4267);
> That's no workaround, that's the way it is done. It is not likely you
> are going to get transparent projection casting, it is a great deal of
> complexity for a very minor operational benefit.
Fair enough.
Corey
