[postgis-users] Same tablename, different schema problems
Don Drake
dondrake at gmail.com
Tue Nov 16 09:13:01 PST 2004
In my development database, running PostGIS version (0.8 USE_GEOS=1
USE_PROJ=1 USE_STATS=1) I created a new schema to test some table
partitioning.
I created a copy of a table in another schema with the same table
name. I was able to create the table, run addGeometry passing in the
schema name, etc. All was good until I ran update_geometry_stats().
I now get the following error message:
ERROR: more than one row returned by a subquery used as an expression
If I rename the table in the test schema, the error message goes away.
Is this a known problem?
Thanks.
-Don
Donald Drake
President
Drake Consulting
http://www.drakeconsult.com/
312-560-1574
