[postgis-users] circular arcs in postgis?
    Hubert Fröhlich
    hubert.froehlich at bvv.bayern.de
    Thu Oct 28 23:12:35 PDT 2004
Hi Paul,
> That depends on what the meaning of "handle" is, and "rudimentary". :)
> The classic "solution" to dealing with arcs and whatnot in a simple
> features environment is to convert them to simple features at load
> time.  So the arc gets replaced with an interpolated line that closely
> approximates its shape.  How does that sound?
I already have a similar approach: saving the "polygon" with arcs and
straight lines mixed in a self defined format ( actually as "text") and
extracting an approximated multipolygon ,with help of a function. The
multipolygon can be extracted "on-the-fly" when needed, or can be
written to a column of its own e.g. by a trigger when a new record is
inserted
However, this results either in reduced performance especially when
dealing with large datasets (several million polygons) and/or, in the
latter case, with the need of storing the same information twice.
Can you imagine a more comfortable approach?
Greetings,
Hubert
> P.
> On 28-Oct-04, at 9:29 AM, Hubert Fröhlich wrote:
>> I am using postgis for storing and processing land register data.
>> However, unfortunately, in our data model, the real estate plots are
>> some kind of "multipolygon", however not in the "OGC Simple Feature
>> for  SQL" sense - which restricts borders to straight lines
>> ( in GML:
>> <gml:LineStringSegment>
>> <gml:pos> 4547584.06 5317944.32 </gml:pos>
>> <gml:pos> 4547590.66 5317944.07 </gml:pos>
>> </gml:LineStringSegment>
>> , but also with cicrular arcs allowed as borders:
>> e.g. in GML
>> <gml:Arc interpolation="circularArc3Points">
>> <gml:pos> 4547582.29 5317942.87 </gml:pos>
>> <gml:pos> 4547582.92 5317943.89 </gml:pos>
>> </gml:Arc>
>> I know this is a rather complicated issue - and I can't avoid it
>> because the "data model" is from the good old days of analog mapping,
>> measuring and calculating ,
>> I know that things (calculations) might turn really VERY complicated,
>> but - is there a chance to extend Postgis data handling so such data
>> types, maybe only in a rudimentary way?
>> Greetings,
>> Hubert
>> Dr.-Ing. Hubert Fröhlich
>> Bezirksfinanzdirektion München
>> Alexandrastr. 3, D-80538 München, GERMANY
>> Tel. :+49 (0)89 / 2190 - 2980
>> Fax  :+49 (0)89 / 2190 - 2997
>> hubert dot froehlich at bvv dot bayern dot de
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
