[postgis-users] can't install on Linux : Makefile.port not found
Darren Houston dhouston at beyondcompliance.ca
Wed Sep 1 19:35:11 PDT 2004
Hello Eduardo,
Try out this document. It will guide you through installing PostGIS into a
pre-installed (operating system installed) PostgreSQL environment. The
document is a little old, but should still be relevant in most parts.
Hope this helps,
Darren H.
Type: text/rtf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040901/fbea5003/attachment.bin>
