[postgis-users] Postgis 0.8.2 doesn't work on Win32
Stefano Bonnin
stefano.bonnin at comai.to
Thu Sep 2 05:44:55 PDT 2004
I'have just installed Postgres 8.0.0beta1 and postgis 0.8.2 with the postgis installer found at
http://dcmms.sourceforge.net/postgis_installer.php
After some test (failed) with mapserver, I tryed to execute very simple query like:
CREATE TABLE gtest ( ID int4, NAME varchar(20) );
SELECT AddGeometryColumn('dbname','gtest','geom',-1,'LINESTRING',2);
INSERT INTO gtest (ID, NAME, GEOM) VALUES (1, 'First Geometry', GeometryFromText('LINESTRING(2 3,4 5,6 5,7 8)', -1));
SELECT id, name, AsText(geom) AS geom FROM gtest;
id | name | geom
1 | First Geometry | LINESTRING(2 3,4 5,6 5,7 8)
SELECT id,name FROM GTEST WHERE GEOM && 'BOX3D(3 4,4 5)'::box3d;
this query crashes the postgres.exe process on "windows XP home SP1"
Can this depend on the OS?
thanks,
RedS
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040902/746af5f1/attachment.html>
