[postgis-users] mapserver with postgis layer
Yingru Cheng
yingru.cheng at premierdata.com
Fri Sep 10 12:48:29 PDT 2004
Hi, all
I have a problem to load postgis layer into mapserver. I am using
postgis 0.8.2, postgreSQL 7.5 and mapserver4.0.2. and also Apache
2.0.49, php 4.3.7.
I have no problem to show shapefiles in the mapserver.
For postgis, I received a prompt dialog saying "postgres.exe has
encountered a problem and needs to close",
Then I received the following:
msDrawMap(): Image handling error. Failed to draw layer named
'postgisogactlease'.
prep_DB(): Query error. Couldnt recover from a bad query: 'DECLARE
mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
wy_ogactlease_clip_tbl WHERE the_geom && setSRID('BOX3D(-106.44029354308
43.3440540930836,-105.185092420256 44.2530829970614)'::BOX3D,
find_srid('','wy_ogactlease_clip_tbl','the_geom') )'
here is part of the map file(layer is in latlong and I want to show it
in utm):
MAP
NAME ITASCA
STATUS ON
SIZE 600 600
EXTENT 425000.0 4800000.0 445000.0 4900000.0
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
IMAGETYPE PNG
PROJECTION
"proj=utm"
"ellps=GRS80"
"zone=13"
"north"
"no_defs"
END
.. //other shape file layers
LAYER
NAME postgisogactlease
TYPE POLYGON
STATUS DEFAULT
CONNECTIONTYPE postgis
CONNECTION "user=test1 password=test1 dbname=demo host=localhost"
DATA "the_geom from wy_ogactlease_clip_tbl"
PROJECTION
"proj=latlong"
"ellps=clrk66"
END
CLASS
COLOR 205 92 82
END
END # postgis layer
END # Map File
I could not tell what is wrong. Anybody saw this before? Anything I
missed?
Thanks and have a good weekend,
cheng
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040910/758778c1/attachment.html>
