[postgis-users] PostGIS 0.9 Upgrade
James McEachern jamesm at threetier.com
Fri Sep 10 15:48:05 PDT 2004
Hi All,
Really newbie question...  from a Microsoftie developer
I have PostgreSQL 7.43/Geos 1.0/PostGIS 0.82 running on FreeBSD 4.10
All running perfect.
So to upgrade Geos/PostGIS, do I do a
make uninstall
make clean
in the old geos 1.0/PostGIS 0.82 install directory first,
before doing the
make
make install
in the geos 2.0/PostGIS 0.90 directory?
I assume the two PostGIS .sql scripts would need to be
run to update the internal table specs and pl functions.
I have never found a clear/clean answer to this type of
proceedure on BSD. I am used to the Windows type of upgrades
and hotfixes.
Thanks in advance.
jamesm
James S McEachern
Three Tier Technologies Corporation
Calgary, Alberta
