[postgis-users] postgis doc in latex
Paul Ramsey
pramsey at refractions.net
Mon Sep 13 08:11:03 PDT 2004
Since we are using XSL to do the docbook-> transformations, you should
look at using the 'fo' (formatting objects) stylesheet instead of the
html stylesheet. Some directions are in the manual:
http://docbook.sourceforge.net/release/xsl/current/doc/publishing.html#d0e250
Check the docs/Makefile for an example of invoking xsltproc.
Paul
TECHER Jean David wrote:
> Hi
> I would like to know if someone has already tried to have the postgis doc
> (file xml)
> in latex (using dblatex (docbook/latex) or something else...)
> Or docbook->latex...without jadetex..
> Thanks
> postgis-users mailing list
