[postgis-users] postgis doc in latex
Paul Ramsey
pramsey at refractions.net
Mon Sep 13 08:43:05 PDT 2004
And now I have added pdf rules to the docs Makefile, and returned the
automatic pdf documentation build to the web site. So everything is now
back to normal (but using XSL! :)
P.
Paul Ramsey wrote:
> Since we are using XSL to do the docbook-> transformations, you should
> look at using the 'fo' (formatting objects) stylesheet instead of the
> html stylesheet. Some directions are in the manual:
> http://docbook.sourceforge.net/release/xsl/current/doc/publishing.html#d0e250
> Check the docs/Makefile for an example of invoking xsltproc.
> Paul
> TECHER Jean David wrote:
>> Hi
>> I would like to know if someone has already tried to have the postgis doc
>> (file xml)
>> in latex (using dblatex (docbook/latex) or something else...)
>> Or docbook->latex...without jadetex..
>> Thanks
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
