[postgis-users] Possible index stats problem?
Alexandre Florio
aflorio at gisplan.com.br
Mon Sep 13 14:28:24 PDT 2004
Em Mon, 13 Sep 2004 20:54:02 +0200
strk at refractions.net escreveu:
> > 4. create lang plpgsql and insert postgis.sql and spatial_ref_sys.sql
> Didn't you get lots of errors in this step ?
No. Why should I get them?
> Estimate is 103. Actual is 413. How many rows in the table ?
5260 rows. Each one's geometry attribute has about 514 points.
> Try also to increment statistics target on the geometry column
> of your table to see if you can get a better estimate.
This is what I've done:
ALTER TABLE municipios ALTER the_geom SET STATISTICS 1000;
> Note that while with PG<8.0 full dataset was inspected with new
> VACUUM ANALYZE integration statistics are gathered inspecting only
> a subset of it. Incrementing target statistics (check postgres manual)
> does increment both the returned subset and the frequency of cells.
> (search_box overlaps 49.000000 cells ...).
Does it explains why analyzing in 8.0 is much faster than in <8.0?
> Let me know.
Unfortunately, no changes:
prototipo-gis=# VACUUM ANALYZE ;
prototipo-gis=# SELECT version();
version
PostgreSQL 8.0.0beta2 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.3.3 20040412 (Gentoo Linux 3.3.3-r6, ssp-3.3.2-2, pie-8.7.6)
(1 row)
prototipo-gis=# select postgis_version();
postgis_version
0.9 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
(1 row)
prototipo-gis=# EXPLAIN ANALYZE SELECT COUNT(*) as cnt FROM "municipios" WHERE (intersects("the_geom", GeometryFromText('POLYGON ((-44.874111 -24.12874, -44.874111 -19.832116, -40.580777 -19.832116, -40.580777 -24.12874, -44.874111 -24.12874))', 4291)) AND "the_geom" && GeometryFromText('POLYGON ((-44.874111 -24.12874, -44.874111 -19.832116, -40.580777 -19.832116, -40.580777 -24.12874, -44.874111 -24.12874))', 4291));
NOTICE: postgis_gist_sel called
NOTICE: search_box overlaps 3721.000000 cells
NOTICE: avg feat overlaps 49.697033 cells
NOTICE: SUM(ov_histo_cells)=1.464153
NOTICE: gain=0.020122
NOTICE: selectivity=0.029462
NOTICE: returning computed value: 0.029462
QUERY PLAN
Aggregate (cost=322.03..322.03 rows=1 width=0) (actual time=48125.695..48125.696 rows=1 loops=1)
-> Seq Scan on municipios (cost=0.00..321.90 rows=52 width=0) (actual time=161.512..48120.603 rows=413 loops=1)
Filter: (intersects(the_geom, 'SRID=4291;POLYGON((-44.874111 -24.12874,-44.874111 -19.832116,-40.580777 -19.832116,-40.580777 -24.12874,-44.874111 -24.12874))'::geometry) AND (the_geom && 'SRID=4291;POLYGON((-44.874111 -24.12874,-44.874111 -19.832116,-40.580777 -19.832116,-40.580777 -24.12874,-44.874111 -24.12874))'::geometry))
Total runtime: 48125.845 ms
(4 rows)
prototipo-gis=# set enable_seqscan=off; SET prototipo-gis=# EXPLAIN ANALYZE SELECT COUNT(*) as cnt FROM "municipios" WHERE (intersects("the_geom", GeometryFromText('POLYGON ((-44.874111 -24.12874, -44.874111 -19.832116, -40.580777 -19.832116, -40.580777 -24.12874, -44.874111 -24.12874))', 4291)) AND "the_geom" && GeometryFromText('POLYGON ((-44.874111 -24.12874, -44.874111 -19.832116, -40.580777 -19.832116, -40.580777 -24.12874, -44.874111 -24.12874))', 4291));
QUERY PLAN
Aggregate (cost=475.69..475.69 rows=1 width=0) (actual time=6718.553..6718.554 rows=1 loops=1)
-> Index Scan using municipios_gidx on municipios (cost=0.00..475.56 rows=52 width=0) (actual time=75.169..6712.530 rows=413 loops=1)
Index Cond: (the_geom && 'SRID=4291;POLYGON((-44.874111 -24.12874,-44.874111 -19.832116,-40.580777 -19.832116,-40.580777 -24.12874,-44.874111 -24.12874))'::geometry)
Filter: intersects(the_geom, 'SRID=4291;POLYGON((-44.874111 -24.12874,-44.874111 -19.832116,-40.580777 -19.832116,-40.580777 -24.12874,-44.874111 -24.12874))'::geometry)
Total runtime: 6718.763 ms
(5 rows)
-- Alexandre
