[postgis-users] PostGIS client
RIBOT Nicolas
nicolas.ribot at c-s.fr
Wed Sep 15 08:09:21 PDT 2004
> PostGIS clients that I know of that can visualize data in PostGIS
> database:
> Safe Software FME
By the way, if anyone have some experience with Postgis and FME viewer:
I try to view a postgis (PG 7.5 + postgis 0.8 on windows) database but with
no success:
I enter DB connection information, i see a new layer in FME viewer but not
the data (composed of 2 points).
Any clue ?
Thanx
Nicolas
Ce message et ses fichiers joints sont confidentiels et destines exclusivement aux destinataires indiques.
Si vous recevez ce message par erreur, merci de le detruire et d’en avertir l’emetteur.
Toute utilisation, diffusion ou publication de ce message non conforme a sa destination est interdite sauf autorisation expresse de l’emetteur.
Les idees et opinions exprimees dans ce message sont celles de son auteur et ne representent pas necessairement celles de CS.
Malgre toutes les dispositions prises par CS, il vous appartient d’effectuer vos propres controles anti-virus avant d’ouvrir les fichiers joints. CS decline toute responsabilite pour toute perte ou dommage resultant de l’utilisation de ce message et/ou des fichiers joints.
This e-mail and its attached files are confidential and intended solely for the adressees indicated below.
If you receive this e-mail in error, please delete it and notify the sender.
Any use, dissemination or disclosure of this e-mail not in accordance with its purpose is prohibited, unless formally approved by the sender.
The ideas or opinions expressed in this e-mail are solely those of its author and do not necessarily represent those of CS.
Despite all the measures taken by CS, you are responsible for processing your own anti-virus checking before opening any attached file. CS shall not be held liable for any loss or damage due to the use of this e-mail or any attached file.
