[postgis-users] postgis doc latex and pdf
David TECHER
davidtecher at yahoo.fr
Wed Sep 15 09:26:02 PDT 2004
Hi Paul
Few days ago, I made the conversion from
postgis-out.xml to postgis.tex and to postgis.pdf
i.e docbook to latex and to pdf...
It's OK... :-)
I used xsltproc from cygwin and dblatex to do the
conversion (dblatex is avalable at
http://dblatex.sourceforge.net
I did :
from doc/Makefile:
postgis.tex: postgis-out.xml
xslt-proc \
--output $@ \
--param shade.verbatim 1 \
--param chunck.section.depth 0 \
/home/david/dblatex-0.1.4.1/xsl/docbook.xsl \
I made two changes in postgis.tex
replace in line 589: 'force_2d' by 'force\_2d' and
'force_3d' by 'force\_3d'
replace in line 2257: 'length_spheroid' by
'length\_spheroid'
I put all *.sty file from dblatex in
postgis-0.9.0/doc in order to compil latex->pdf.
I made few changes on *.sty for the author of the file
(Tilte: PostGIS 0.9.0, Author: Paul Ramsey....)
then
pdflatex postgis.tex
The PDF is avalable at
http://www.01map.com/david/doc/postgis090/postgis.pdf
ALL files (postgis.tex,postgis.pdf,*.sty) are avalable
at
http://www.01map.com/david/doc/postgis090/postgis090.zip
TECHER JEAN DAVID
- Responsable Informatique 01MAP -
e-mail:davidtecher at yahoo.fr
Tél: 06 85 37 36 75
Site PostGIS:
http://techer.pascal.free.fr/postgis/index.htm
> -----Message d'origine-----
> De : postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]De
la part de Paul
> Ramsey
> Envoyé : lundi 13 septembre 2004 18:01
> À : PostGIS Users
> Objet : Re: [postgis-users] postgis doc in latex
> TECHER Jean David wrote:
> > Can you send me the postgis.fo ???
> No way, it is a derived file, it should not be
hand-edited.
> > I will made the conversion too?? thanks
> Yes, do the conversion. If you have fedora core 1,
all the packages you
> need (xmltex, passivetex, libxslt,
docbook-style-xsl, docbook-dtds) are
> available as standard distribution RPMs.
> postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Vous manquez despace pour stocker vos mails ?
Yahoo! Mail vous offre GRATUITEMENT 100 Mo !
Créez votre Yahoo! Mail sur http://fr.benefits.yahoo.com/
Le nouveau Yahoo! Messenger est arrivé ! Découvrez toutes les nouveautés pour dialoguer instantanément avec vos amis. A télécharger gratuitement sur http://fr.messenger.yahoo.com
