[postgis-users] PointM, PolyLineM, PolygonM, ...
strk at refractions.net
Thu Sep 23 04:03:56 PDT 2004
On Thu, Sep 23, 2004 at 12:12:28PM +0200, Pierrick Brihaye wrote:
> Hi,
> strk at refractions.net a écrit :
> > Now that postgis supports up to 4 dimensions geometry, what do you
> >think should be done ? My vision is this:
> >Type <-> geometry2d
> >TypeM <-> geometry3d
> >TypeZ <-> geometry4d
> >What do you think ?
> How long shall we pay for ESRI's weird data model ? :-)
> IMHO, the 3rd dimension has well-known semantics : Z.
> Therefore, any other dimension should be considered as a 4th one.
> Any other thoughts ?
I'm with you, but quetions are:
1) how should we import TypeM shapefiles ?
a) as x,y,Z,m // wasting Z space in postgis
b) as x,y,z // interpreting M as Z
2) how should we import TypeZ shapefiles ?
a) as x,y,z,m // respecting shapefile meanings
b) as x,y,z,m // swapping M<->Z meaning
c) as x,y,z // discarding M
d) as x,y,z // using M, discarding Z
3) how should we export geometry3d ?
a) as TypeM // using M for Z values
b) as TypeZ // wasting M space in shapefile
3) how should we export geometry4d ?
a) as TypeZ // respecting shapefile meanings (4th dim -> M)
b) as TypeZ // swapping M<->Z meaning
Does anyone see the light ?
I suppost some command line switches would do but finding an easy
interface is not straightforward ...
--strk;
> Regards,
> Pierrick Brihaye, informaticien
> Service régional de l'Inventaire
> DRAC Bretagne
> mailto:pierrick.brihaye at culture.gouv.fr
> +33 (0)2 99 29 67 78
> postgis-users mailing list
