[postgis-users] Postgis + native Windows PostgreSQL
TECHER Jean David
davidtecher at yahoo.fr
Thu Sep 30 05:38:17 PDT 2004
> Is there any other solution than replacing the variable $libdir to the
> full path to postgis.dll?
you can use postgis.sql without chaging $libdir
example if after installation postgis is at c:\pgsql\share\posygis.sql do
psql -d your_database -c "\i c:/psql/lib/share/postgis.sql"
TECHER Jean David
Responsable Informatique 01MAP
e-mail: davidtecher at yahoo.fr
site: http://techer.pascal.free.fr/postgis/
----- Original Message -----
To: <postgis-users at postgis.refractions.net>
Sent: Thursday, September 30, 2004 2:23 PM
Subject: [postgis-users] Postgis + native Windows PostgreSQL
> Hallo.
> I am trying to move data from the older version of PostgreSQL database.
> After installing Postgresql 8.0-beta2-dev3 and PostGIS 0.9.0 (and
> stopping the database run under Cygwin), there are still errors in the
> error log. I am using psql prior to newer version.
> psql -e template1 < db.dump 2> error.txt
> error.txt
> NOTICE: type "histogram2d" is not yet defined
> DETAIL: Creating a shell type definition.
> ERROR: could not access file "$libdir/postgis.dll": No such file or
> directory
> ERROR: type histogram2d does not exist
> ERROR: function histogram2d_in(cstring) does not exist
> NOTICE: type "box3d" is not yet defined
> directory
> ERROR: type box3d does not exist
> ERROR: function box3d_in(cstring) does not exist
> I thought that the problem with the different environment would be solved.
> full path to postgis.dll? In my opinion the standard dump created by
> previous version of PostgreSQL should be usable without editing for
> loading to new native version of database.
> Anyway thanks very much to both groups of developers for the release of
> the native Windows version. The performance improvement and locales
> support is perfect.
> Best regards,
> Vojtech Honzik
> postgis-users mailing list
