Re: [postgis-users] Besoin d'aide suite à l'installation de postresqlwin
Jean David TECHER
davidtecher at yahoo.fr
Tue Aug 2 01:24:36 PDT 2005
Hi Trico
First of all excuse-me for my being late to answer...
Then this list is not French but English...So please send your messages in English and not in French
DROP MY DISTRIB 'psqlwin'..This distrib have been made last year..So it is to old.
U have two solutions. Choose one of them.
I - using Win32 installers done by MCA & PostgreSQL's Team (Hagander) ..U will find the follwoing URL
PostgreSQL : ftp://ftp.fr.postgresql.org/win32/postgresql-8.0.3.zip
PostGIS + Geos + Proj: http://www.webbased.co.uk/mca/ download link 'PostGIS 1.0.2 release'
II - Downloading a binary distribution and doing a manually installation
You can find this distrib from this link:
http://www.01map.net/david/win32/download/postgresql-8.0.3_postgis-1.0.2_geos-2.1.3_proj-4.4.9.zip
Create a directory named 'PostgreSQL' here c:\PostgreSQL'
Unzip the zip file there in 'C:\PostgreSQL'...You should get c:\PostgteSQL\8.0.3\bin, C:\PostgreSQL\8.0.3\lib, C:\PostgreSQL\8.0.3\share and so on....
Create the following environment varaibles:
PGHOME = C:\PostgreSQL\8.0.3
PGDATA= C:\PostgreSQL\8.0.3
Then add of the beginning of your PATH variable:
PATH = C:\PostgreSQL\8.0.3\bin;C:\PostgreSQl\8.0.3\lib;.....
Create a User on windows called 'postgres' without any privileges administrator ... Log on windows as postgres ..;On a DOS prompt type
initdb -A trust -E SQL_ASCII
the following instructions in French an with explanations could be found here
http://www.01map.net/david/win32/doc/html/ch03.html
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
----- Original Message -----
To: postgis-users at postgis.refractions.net
Sent: Monday, August 01, 2005 6:57 PM
Subject: [postgis-users] Besoin d'aide suite à l'installation de postresqlwin
Bonjour
j'ai le répertoire psqlwin sous minGW, mais je tiens à préciser que je n'ai pas de répertoire data.
Lorsque j'essaie de créer un user, il me dit pas possible pb port 5432, que dois-je faire?
D'autre part, dans mon bouqin il est écrit de taper les commandes suivantes:
createuser -d -U dbuser
a ce moment là, il m'est demander de rentrer un nom de user, puis-je choisir n'importe lequel?
Ensuite, il m'est dit de taper la commande createdb -U dbuser COREJAVA, pouvez vous m'expliquer ces deux manip en détails?
Merci pour vos explications
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
Téléchargez le ici !
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050802/e236714a/attachment.html>
