Fwd: Fw: [postgis-users] Gentoo Emerge (from Gerald FENOY)
Jaakko Kahkonen jaakko.kahkonen at fgi.fi
Thu Aug 4 03:06:33 PDT 2005
I have a new installation of Gentoo-Linux and problems with
postgis-1.0.1_p20050727. Postgresql-8.0.3 is installed.
jakpc ~ # emerge -puv postgis
These are the packages that I would merge, in order:
Calculating dependencies       ...done!
[ebuild  N    ] dev-db/postgis-1.0.1_p20050727  +doc +geos +proj 0 kB [1]
Total size of downloads: 0 kB
Portage overlays:
  [1] /usr/local/portage
jakpc ~ # emerge -uv postgis
 >>> emerge (1 of 1) dev-db/postgis-1.0.1_p20050727 to /
 >>> md5 files   ;-) postgis-1.0.1_p20050727.ebuild
 >>> md5 files   ;-) files/digest-postgis-1.0.1_p20050727
 >>> md5 src_uri ;-) postgis-cvs-1.0.1_p20050727.tar.gz
 >>> Unpacking source...
1.0.1_p20050727
 >>> Unpacking postgis-cvs-1.0.1_p20050727.tar.gz to
/var/tmp/portage/postgis-1.0
.1_p20050727/work
 >>> Source unpacked.
  * Building doc with xsl-stylesheets-1.68.1-r1
  * econf: updating postgis-cvs/config.guess with
/usr/share/gnuconfig/config.gue
ss
  * econf: updating postgis-cvs/config.sub with
/usr/share/gnuconfig/config.sub
./configure --prefix=/usr --host=i686-pc-linux-gnu
--mandir=/usr/share/man --inf
odir=/usr/share/info --datadir=/usr/share --sysconfdir=/etc
--localstatedir=/var
/lib --build=i686-pc-linux-gnu --enable-autoconf --with-maxbackends=1024
--with-
geos=/usr/bin/geos-config --with-proj=/usr
  * doc will be built
./configure
make -C utils
make[1]: Entering directory
`/var/tmp/portage/postgis-1.0.1_p20050727/work/postg
is-cvs/utils'
chmod +x postgis_restore.pl create_undef.pl postgis_proc_upgrade.pl
profile_inte
rsects.pl test_estimation.pl test_joinestimation.pl
make[1]: Leaving directory
`/var/tmp/portage/postgis-1.0.1_p20050727/work/postgi
s-cvs/utils'
./config.status
make: ./config.status: Command not found
make: *** [Makefile.config] Error 127
!!! ERROR: dev-db/postgis-1.0.1_p20050727 failed.
!!! Function src_compile, Line 63, Exitcode 2
!!! Error: emake failed
!!! If you need support, post the topmost build error, NOT this status
message.
jakpc ~ #
What should I try to do to fix this?
Jaakko
