Fwd: Fw: [postgis-users] Gentoo Emerge (from Gerald FENOY)
Christo Du Preez christo at mecola.com
Thu Aug 4 03:25:55 PDT 2005
Try leaving out doc. I have experienced problems when trying to include doc.
Jaakko Kahkonen wrote:
> Hi,
> I have a new installation of Gentoo-Linux and problems with
> postgis-1.0.1_p20050727. Postgresql-8.0.3 is installed.
> jakpc ~ # emerge -puv postgis
> These are the packages that I would merge, in order:
> Calculating dependencies       ...done!
> [ebuild  N    ] dev-db/postgis-1.0.1_p20050727  +doc +geos +proj 0 kB [1]
> Total size of downloads: 0 kB
> Portage overlays:
>  [1] /usr/local/portage
> jakpc ~ # emerge -uv postgis
> >>> emerge (1 of 1) dev-db/postgis-1.0.1_p20050727 to /
> >>> md5 files   ;-) postgis-1.0.1_p20050727.ebuild
> >>> md5 files   ;-) files/digest-postgis-1.0.1_p20050727
> >>> md5 src_uri ;-) postgis-cvs-1.0.1_p20050727.tar.gz
> >>> Unpacking source...
> 1.0.1_p20050727
> >>> Unpacking postgis-cvs-1.0.1_p20050727.tar.gz to
> /var/tmp/portage/postgis-1.0
> .1_p20050727/work
> >>> Source unpacked.
>  * Building doc with xsl-stylesheets-1.68.1-r1
>  * econf: updating postgis-cvs/config.guess with
> /usr/share/gnuconfig/config.gue
> ss
>  * econf: updating postgis-cvs/config.sub with
> /usr/share/gnuconfig/config.sub
> ./configure --prefix=/usr --host=i686-pc-linux-gnu
> --mandir=/usr/share/man --inf
> odir=/usr/share/info --datadir=/usr/share --sysconfdir=/etc
> --localstatedir=/var
> /lib --build=i686-pc-linux-gnu --enable-autoconf
> --with-maxbackends=1024 --with-
> geos=/usr/bin/geos-config --with-proj=/usr
>  * doc will be built
> ./configure
> make -C utils
> make[1]: Entering directory
> `/var/tmp/portage/postgis-1.0.1_p20050727/work/postg
> is-cvs/utils'
> chmod +x postgis_restore.pl create_undef.pl postgis_proc_upgrade.pl
> profile_inte
> rsects.pl test_estimation.pl test_joinestimation.pl
> make[1]: Leaving directory
> `/var/tmp/portage/postgis-1.0.1_p20050727/work/postgi
> s-cvs/utils'
> ./config.status
> make: ./config.status: Command not found
> make: *** [Makefile.config] Error 127
> !!! ERROR: dev-db/postgis-1.0.1_p20050727 failed.
> !!! Function src_compile, Line 63, Exitcode 2
> !!! Error: emake failed
> !!! If you need support, post the topmost build error, NOT this status
> message.
> jakpc ~ #
> What should I try to do to fix this?
Kind Regards,
Christo Du Preez
Senior Software Engineer
Mecola IT
http://www.mecola.com
+27 [0]82 4255 895
