[postgis-users] segmented road data to svg
Christo Du Preez
christo at mecola.com
Thu Aug 4 03:09:40 PDT 2005
I have road data imported using shp2pgsql. The database table is made up
of 'MULTILINESTRING's.
Unfortunately the data is very segmented, making live very difficult
trying to Simplify the data and using the intersection function and also
results in a big svg result.
I've tried to use collect, GeomUnion and also polygonize_garray but I
cant get it right. What is the best procedure to build my roads up from
all the segments parts so I can run a query similar to the example on
the resulting data/table:
SELECT province AS name,
AsSVG(intersection(Simplify(the_geom,0.016),GeometryFromText('POLYGON((17
-35,25 -35,25 -29,17 -29,17 -35))',-1)),0,6) AS svg_geom
FROM province
WHERE the_geom && setSRID('BOX3D(17 -35, 25 -29)'::box3d,-1) ORDER BY
province ASC
Thanx in advance.
