Fwd: Fw: [postgis-users] Gentoo Emerge (from Gerald FENOY)
Gérald Fenoy
gfenoy at gmail.com
Thu Aug 4 08:37:52 PDT 2005
I've just finish to solve the problem with the documentation
generation. Could you guys try the new ebuild version (available here
: http://gentoo.01map.net/dev-db/postgis/postgis-1.0.1_p20050727-r1.ebuild)
and send me feedbacks please ?
Cordially.
2005/8/4, Jaakko Kahkonen <jaakko.kahkonen at fgi.fi>:
> It helped, thanks!
> Jaakko
> Christo Du Preez wrote:
> > Try leaving out doc. I have experienced problems when trying to include
> > doc.
> > Jaakko Kahkonen wrote:
> >> Hi,
> >> I have a new installation of Gentoo-Linux and problems with
> >> postgis-1.0.1_p20050727. Postgresql-8.0.3 is installed.
> >> jakpc ~ # emerge -puv postgis
> >> These are the packages that I would merge, in order:
> >> Calculating dependencies ...done!
> >> [ebuild N ] dev-db/postgis-1.0.1_p20050727 +doc +geos +proj 0 kB [1]
> >> Total size of downloads: 0 kB
> >> Portage overlays:
> >> [1] /usr/local/portage
> >> jakpc ~ # emerge -uv postgis
> >> >>> emerge (1 of 1) dev-db/postgis-1.0.1_p20050727 to /
> >> >>> md5 files ;-) postgis-1.0.1_p20050727.ebuild
> >> >>> md5 files ;-) files/digest-postgis-1.0.1_p20050727
> >> >>> md5 src_uri ;-) postgis-cvs-1.0.1_p20050727.tar.gz
> >> >>> Unpacking source...
> >> 1.0.1_p20050727
> >> >>> Unpacking postgis-cvs-1.0.1_p20050727.tar.gz to
> >> /var/tmp/portage/postgis-1.0
> >> .1_p20050727/work
> >> >>> Source unpacked.
> >> * Building doc with xsl-stylesheets-1.68.1-r1
> >> * econf: updating postgis-cvs/config.guess with
> >> /usr/share/gnuconfig/config.gue
> >> ss
> >> * econf: updating postgis-cvs/config.sub with
> >> /usr/share/gnuconfig/config.sub
> >> ./configure --prefix=/usr --host=i686-pc-linux-gnu
> >> --mandir=/usr/share/man --inf
> >> odir=/usr/share/info --datadir=/usr/share --sysconfdir=/etc
> >> --localstatedir=/var
> >> /lib --build=i686-pc-linux-gnu --enable-autoconf
> >> --with-maxbackends=1024 --with-
> >> geos=/usr/bin/geos-config --with-proj=/usr
> >> * doc will be built
> >> ./configure
> >> make -C utils
> >> make[1]: Entering directory
> >> `/var/tmp/portage/postgis-1.0.1_p20050727/work/postg
> >> is-cvs/utils'
> >> chmod +x postgis_restore.pl create_undef.pl postgis_proc_upgrade.pl
> >> profile_inte
> >> rsects.pl test_estimation.pl test_joinestimation.pl
> >> make[1]: Leaving directory
> >> `/var/tmp/portage/postgis-1.0.1_p20050727/work/postgi
> >> s-cvs/utils'
> >> ./config.status
> >> make: ./config.status: Command not found
> >> make: *** [Makefile.config] Error 127
> >> !!! ERROR: dev-db/postgis-1.0.1_p20050727 failed.
> >> !!! Function src_compile, Line 63, Exitcode 2
> >> !!! Error: emake failed
> >> !!! If you need support, post the topmost build error, NOT this status
> >> message.
> >> jakpc ~ #
> >> What should I try to do to fix this?
> postgis-users mailing list
Gérald FENOY
01map.net
