[postgis-users] Projection question
Markus Schaber
schabi at logix-tt.com
Tue Aug 9 05:19:35 PDT 2005
Hi, Ehud,
Ehud Shabtai wrote:
> As I have data from all around the world, is there a single projection
> which would preserve the distance for every location?
Sadly, there is none, as it is geometrically impossible to project a
spherical object into a plain one without loss.
Maybe the best idea is to use a group of zone projections that cover the
whole planet (e. G. UTM) and then write a plpgsql function that maps a
geometry to the appropriate zone srid. This would allow you to write
something like:
transform(buffer(transform(the_geom, find_utm_srid(the_geom)), 100, 4326);'
HTH,
Markus
