[postgis-users] Generating Point geometry
Markus Schaber schabi at logix-tt.com
Wed Aug 10 04:13:26 PDT 2005
Hi, Robyn,
Robyn Rennie wrote:
> I am using PostGIS 1.0.0. Nothing in the documentation specifies what
>  that values for the last argument must be - I saw lots of examples
> with LINESTRINGS and a value of 2 but the command reference does not
> elaborate on any of the arguments. So I picked 1 for a 1 dimensional
> point.
Dimension here simply means the number of ordinates every vertex of the
Geometry has.
There's a different meaning of dimensionality, however, that can often
confuse us. If you think in OpenGIS SFS spec geometry dimensionality
terms, then a Point has 0, a LineString has a dimensionality of 1 and
polygonal objects have a dimensionality of 2 :-)
HTH,
Markus
