[postgis-users] PostGIS installation problem: contrib folder
Justin
authalic at yahoo.com
Wed Aug 10 07:53:52 PDT 2005
Hi readers.
I'm trying to install PostGIS on a new Linux machine
and I'm running into some difficulty. I'm totally new
to PostGIS and fairly new to Linux, so this may be a
simple problem.
I installed PostgreSQL (version 8.0.3) from source
code using default settings. It appears to be working
correctly. The installation steps for PostGIS say
that I need to uncompress and untar the archive in the
"contrib" directory of the PostgreSQL source tree, but
there doesn't appear to be a "contrib" folder anywhere
in my PostgreSQL file structure.
Did I miss a step? Is it possible to just create a
new "contrib" folder and untar the PostGIS archive
there? If so, what is the default location of the
"contrib" folder?
Thanks.
Justin
____________________________________________________
Start your day with Yahoo! - make it your home page
http://www.yahoo.com/r/hs
