[postgis-users] Points within range of line
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Aug 11 14:24:35 PDT 2005
Adrian,
This is probably much faster, especially if the line is complex, and it
uses a spatial index on the point_table is you build one where the_geom
is the geometry column for the points and "dist" is the distance you
want and line is the line geometry.
select * from point_table where expand(the_geom, dist) && line and
distance(the_geom, line) < dist;
-Steve
http://imaptools.com
Adrian Holovaty wrote:
> Given a PostGIS-enabled table of points, what's the best way to retrieve all
> the points that are within a certain distance of a given line? The line can
> have an arbitrary number of points (i.e., it's not straight).
> Surely this is a solved problem. Thanks for any help -- I'm still
> learning! :-)
> Adrian
> postgis-users mailing list
