[postgis-users] Points within range of line
Sean Gillies sgillies at frii.com
Thu Aug 11 14:55:49 PDT 2005
On Aug 11, 2005, at 3:15 PM, Adrian Holovaty wrote:
> David Bitner wrote:
>> select intersection(points,buffer(line,distance))
>> where points is the points geometry
>> line is your line geometry
>> and distance is the size of your buffer
> Thanks, David!
> Adrian
Just curious, Adrian, have you started to work yet on any sort of GIS
feature model for Django?
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
