[postgis-users] Projections and Functions (was Simple question: How to get projected distance?)
Gustavo Henrique Sberze Ribas
gribas at cpqd.com.br
Fri Aug 12 13:57:53 PDT 2005
> If you are not super concerned about accuracy, create a
> planar project for your region of interest (CONUS, right?)
> and use that instead of figuring out the right UTM zone on
> the fly. I think there are some nice
> Lambert parameterizations that do all of CONUS. You can just
> insert the
> relevant definnitions into spatial_ref_sys and go from there.
Paul, what if my region of interest covers the whole world?
Would you be so kind as to elaborate your idea? I'm a bit
confused.
>> One last question - Is this cycle of WGS84 -> UTM -> WGS84
>> considered best practice i.e. is this the easiest way to
>> accomplish what I need?
I don't know if it's the best way, but it's easy and it seems
to work. However I keep asking myself what would happen if
I create a buffer of 1km real close to the border that
delimit a zone, will the Easting and Northing be correctly converted
back to lat/long?
>> It would imply that I need to add logic to figure the right
>> intermediate UTM zone.
Now that's easy, to get the UTM zone of a lat/long coordinate:
select (round((X($1)+180)/6 + 0.5))::int
where $1 is a geometry. The boring thing is to create a table
that will map all UTM's SRID.
or you could create some functions like
toUTM(geometry)
toLongLat(geometry)
where it assumes the ellipsoid of the given geometry to calculate
the output.
Gustavo
