[postgis-users] Geocoder for PostGIS
    David Bitner
    osgis.lists at gmail.com
    Mon Aug 15 06:40:56 PDT 2005
I've got my PL/PGSQL / PL/Perl geocoder at http://foo.gyttja.org.  I
have tried to develop it so that it could have different types of
datasets plugged in.  I'm all for getting a standard base.
I would propose keeping the work completely within the database, I
have found that PL/Perl is great for the address parsing, but it adds
a requirement for the user.  Additional "clients" could then be added
for PHP or Perl or ASP or whatever to access the PostgreSQL/PostGIS
geocode function.
In order to make a worldwide geocoder, we should keep as many
components of the geocoder separate as possible so that we can reuse
as much code as possible between localizations.  The two
functionalities that will change between geocoders depend on the local
way of presenting an address (ie 4000 East Harriett Parkway,
Minneapolis, MN 55560) and the type of dataset geocoding agains (do
you have both left and right address ranges, can we make a function
that geocodes off parcel data).  We should also have some functions to
standardize and index the information in the source data.
On 8/15/05, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Paul,
> I think we might need to define the code and/or development environment
> also. For example is it going to be:
> 1. inside postgres
> 2. php, perl, C, java, etc or one language and wrappers, etc
> It would be nice to see a design section that would be organized by
> country that people with local knowledge can update with country
> specific addressing requirements and address parsing requirements, etc.
> A data section, that is more oriented to identifying data sources as
> opposed to storing data by country might be useful.
> Just some thoughts,
>    -Stephen Woodbridge
>     http://imaptools.com
> Paul Scott wrote:
> > On Mon, 2005-08-15 at 05:29 -0400, "René F. Viancos S." wrote:
> >> Someone knows an opensource development  for geocoding in PostGIS
> >> and/or PHP
> > Seeing as though this thread comes up with _alarming_ regularity, I
> > propose that we *start* a project for exactly this.
> > We could divide the source tree by country, and let everyone
> > interested contribute some country specific code. Once that is done,
> > try then to create a generic "world-geocoder" of sorts. I am sure
> > that the Mapserver Community would also like to get involved.
> > I am prepared to host such  a project, as well as provide additional
> > mailing lists etc, to keep it off this list (eliminating unnecessary
> > mail to uninterested parties).
> > Comments? Thoughts? Flames?
> > I could have this set up in a matter of minutes, so let me know. I
> > think that this project will create some respite for all users of
> > this list :)
> > --Paul
> > _______________________________________________ postgis-users mailing
> > list postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> postgis-users mailing list
