[postgis-users] Geocoder for PostGIS
Stephen Woodbridge woodbri at swoodbridge.com
Mon Aug 15 10:16:50 PDT 2005
Well, I for one would like to see it in postgres/postgis, but that
doesn't stop us from building both or at least keep the project oriented
toward collecting the information that is needed for any implementation
in a common place.
For what its worth, Refractions has post a Tiger geocoder on their site,
and Jocelyn Turcotte & Jean-Denis Giguere have post another geocoder
that works out of postGIS.
I have looked over both of these and Schuyler's major deficit is in any
smart address parsing and standardization. This will be the key to
making a good geocoder. Parsing and standardization really needs to be
dictionary based and pluggable.
Geocoding is nothing more than matching the address someone enters
against a database to get a street segment and then interpolate along
the segment to the house number  to get the location. The later part is
just math, the database does the matching, but the really hard part is
converting the address using country specific rules and standards and
abbreviations and common miss spellings, etc into standardized tokens
that can be matched.
If we can workout the design and algorithm issues, then it can easily be
implemented in any language the support these goals.
-Steve
Paul Scott wrote:
>>>>abe.gillespie at gmail.com 08/15/05 4:36 PM >>>
> I disagree with making a universal geocoder depend on PostGIS.  I
> think it's a better idea to have it completely independent of PostGIS.
> I must agree with this sentiment. I, personally, would rather go the
> route of a PHP, Perl or Python framework that could instantiate a
> country "module" as needed. Something like a core set of functions (db
> abstraction, output template etc) with a pluggable module for each
> country with the parcel specific data for that country/territory. That
> would make it a lot more efficient, as I would say only install the core
> + the South Africa module.
> The database should exist as it is, I wouldn't want to get too deep into
> that, rather use webservices (SOAP, REST etc) or a hardy abstraction
> layer to talk to the data. Let the scripting language do what it does
> best, that is parse the data to be useful to "end users", without
> putting unnecessary pressure on the db.
> --Paul
> postgis-users mailing list
