[postgis-users] deriving distance between lat/long points.
Brent Wood
pcreso at pcreso.com
Wed Aug 17 11:08:20 PDT 2005
--- Ethan Alpert <ealpert at digitalglobe.com> wrote:
> Is the function distance_spheroid not available in v0.8? This does the
> trick without reprojecting the data.
> -e
It is, but as in the example below, I continue to get NaN results with what I
think are valid input parameters:
Any suggestions? Is it likely that other spheroids my work better? I assumed it
would be fine using the spheroid of the input data projection.
Thanks,
Brent
(From the original post)
> I have not been able to get distance_spheroid or length_spheroid to
> work, & distance_sphere doesn't exist in postgis.sql. I have no say on
> the versions to be installed, and can but hope for an upgrade someday.
> Parameters:
> Line: GeometryFromText('LINESTRING(160 -45,180 -45)', 4326)
> Start point: GeometryFromText('POINT(160 -45)', 4326)
> End point: GeometryFromText('POINT(180 -45)', 4326)
> Spheroid = SPHEROID["WGS_1984",6378137,298.257223563]
> SRID: 54027
> distance(point,point)
> 4616.85
> distance_spheroid(point, point, spheroid)
> NaN
> [woodb at otter ~]$ arc_dist -45 160 -45 180
> Parameters:
> SRID: 54032
> 1747.37
> NaN
> [woodb at otter ~]$
& the script code:
> echo "distance_spheroid(point, point, spheroid)"
> psql $DB -U woodb -q -A -t -c "select (distance_spheroid($START , $END,
> '$SPHEROID' )/1000)::decimal(9,2) as Km;"
