[postgis-users] shp2pgsql and multibyte shape files
Jorg Heymans
jh at domek.be
Thu Aug 18 08:10:53 PDT 2005
Does shp2pgsql support multibyte characters in shapefiles ? We are
trying to upload a shapefile containing japanese characters into our
database without success :
ERROR: invalid byte sequence for encoding "EUC_JPZ" 0x956c
ROLLBACK COPY bu_major, line 9, column a: "¬§Ùl¬w
for other similar shapefiles we get
ERROR: invalid byte sequence for encoding "EUC_JP": 0x956c
ROLLBACK COPY merkel, line 1, column a: "Ƽùºè┘òlżèwìZ"
(note how the first errormessage talks about EUC_JPZ and the second
about EUC_JP)
The database [2] is setup with EUC_JP encoding. I verified this by
inserting japanese into it over JDBC.
Thoughts ?
Regards
Jorg Heymans
[1]
http://postgis.refractions.net/pipermail/postgis-devel/2005-January/000798.html
[2]
POSTGIS="1.0.2" GEOS="2.1.3" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.3.0" RELPROC="0.3.0"
