[postgis-users] shp2pgsql and multibyte shape files
strk at refractions.net
Thu Aug 18 12:24:00 PDT 2005
For multibyte support you should set the USE_ICONV
variable in Makefile.config (or in the environment).
Then in the loader/ directory:
make clean; make
If everything goes ok you should have a new -W switch with
which specifying source encoding.
--strk;
On Thu, Aug 18, 2005 at 05:10:53PM +0200, Jorg Heymans wrote:
> Hi,
> Does shp2pgsql support multibyte characters in shapefiles ? We are
> trying to upload a shapefile containing japanese characters into our
> database without success :
> ERROR: invalid byte sequence for encoding "EUC_JPZ" 0x956c
> ROLLBACK COPY bu_major, line 9, column a: "¤Ãl¬w
> for other similar shapefiles we get
> ERROR: invalid byte sequence for encoding "EUC_JP": 0x956c
> ROLLBACK COPY merkel, line 1, column a: "üùºèâòlÃ
¼èwìZ"
> (note how the first errormessage talks about EUC_JPZ and the second
> about EUC_JP)
> The database [2] is setup with EUC_JP encoding. I verified this by
> inserting japanese into it over JDBC.
> Thoughts ?
> Regards
> Jorg Heymans
> [1]
> http://postgis.refractions.net/pipermail/postgis-devel/2005-January/000798.html
> [2]
> POSTGIS="1.0.2" GEOS="2.1.3" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> DBPROC="0.3.0" RELPROC="0.3.0"
> postgis-users mailing list
