[postgis-users] error in using Contains command
orkun temiz at deprem.gov.tr
Fri Aug 19 07:15:28 PDT 2005
hello
I compiled postgis  using "./configure --with-proj-libs=/usr/local/lib/
--with-geos-libs=/usr/local/lib/",make ,make install" and
I got no error.
But when I used sql commands as:
template1=# SELECT id, geom FROM gtest
template1-# where geom && 'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))'
template1-# AND Contains(geom,'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))');
ERROR:  contains:: operation not implemented - compile PostGIS with JTS
or GEOS support
what might be the problem ?
regards
Ahmet Temiz
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
